How to solve this issue of line weight
From the View Tab check the Line Thin/Thick command to see if it’s just this.
Then you need to check Visibility Graphics (VG) to check for overrides and also the Filter Tab for and rule based overrides.
Also are they the same Discipline and Phase? (Properties Palette)
Tip - select both wall styles and see the difference in Parameters in the Properties Palette!
Yes. I checked my filters in visibility Graphic & Still have the problem
Yes same discipline
the thick line looks like a single line wall are the wall styles correct?
Phases are the same?
in the View Control Toolbar does changes the detail Level from Coarse to Medium or Fine help.
Can you upload the files we will just be guessing!
I am not exactly sure what you are trying to achieve? Is it a wall around another wall?
But look at the Blue Icon at the Top "Thin Lines" and the Pop-Up Menu at the Bottom Detail Level"
my target is in printing not to view the model . I already activate thin lines
I can only assume it’s the wall styles themselves if you have checked everything else!
By default only the outer shrink-wrap lines are presented by Wall Cut Line style defined in the Object styles. All the interior lines are the same thinner line weight. If you want to override the interior lines, VG and tick the Cut Line style box bottom right of the window, there you will be able to set each of the layer function with an unique line style.
This is what you check normally to see where the problem lies.
Go to VG and uncheck this box.
Check the Silhouettes and set it to none
