I have a problem with revit showing the lineweights cut in section as thin lines, but thye should show as thick if they cut through something.
view is on medium
see picture
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
check your VG maybe there is overrides changes or try type TL. thanks
TL is on, that not the problem.
and I'm not sure what I'm looking for in VG? ( see photo)
change detail level to fine or coarse and see if helps. thanks
Still have the issue.
Surely this must have something to do with the wall family. the roof is correct its just the wall that doesn't understand that is should graphically display as cut through plasterboard and exterior cladding.
By default only the outer shrink-wrap lines are presented by Wall Cut Line style defined in the Object styles. All the interior lines are the same thinner line weight. If you want to override the interior lines, VG and tick the Cut Line style box bottom right of the window, there you will be able to set each of the layer function with an unique line style.
