Hi all,I'm making a building student residence. After some tests, I decided to use linked models for every type of room. I ticked "room boundaries" in the linked model type properties, both in Link A and in Link B. The room doesn't recognize the boundaries from Link B, whereas it works well for Link A.
I created Link B by copying Link A, and I justed moved the walls.
Does anyone have a clue ?
Best Regards,
Raphael
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Open Link B and confirm the walls are Room Bounding.
If they already are, can you cut a section through both Link A and Link B from that view and show it?
