walls from massing problem with changing location
hemmanu
Message 1 of 10
hemmanu
I have created a special shape massing, upload it to the project.
the location of the massing can be change in all direction.
when I create walls by face, I can move them only on the same height the massing was located in.
is there a way to get rid of this constraint?
thanks.
Replies (9)
Message 2 of 10
Why don't you change the mass, select the walls and choose update to faces?
Message 3 of 10
That's always bothered me too. You'd think Revit would be smarter than that.  Oh well, Update to Face.
Message 4 of 10
hemmanu
thank you both to the replies,
The massing i have created is planned to be a base for a light roof, so i need to add lots of them to the project. since the light roof is in a tilt i have to set each of there to a specific location and height.
so to change the mass for each of them is not relevant.....
i have choose the following way,
i loaded the mass to the project, copy it be array (without grouping) and then set each of them to the right position and than cover them with metal walls......
AT-1006-5-GM-Belinson_station_נושא דו ראשי_22082018.jpgAT-1006-5-GM-Belinson_station_נושא דו ראשי2_22082018.jpgAT-1006-5-GM-Belinson_station_נושא דו ראשי2_22082018.jpg
Message 5 of 10
Corsten.Au
Hi
Easiest way would be to use " Structural Framing System "
Frames can be rotated in any direction, achieving desired slope etc..
each beam can be customised to required design...
Structural Framing with BeamStructural Framing with BeamCustomised Beam ( framing )Customised Beam ( framing )spacing and typespacing and type
Corsten
Building Designer
Message 6 of 10
hemmanu
thanks, i will try to do it this way, thanks.
Message 7 of 10
hemmanu
hi Ganesh,
is there an option to convert the massing i have created to Structural Framing System " ??
or copying the structure (ref plans and so) to a new family based on " Structural Framing System " ?
thanks, Hagay
Message 8 of 10
Corsten.Au
Not really.
You may export current mass in CAD for tracing ..
create a new frame and edit the structural beam to get the shape from CAD..
1. Use structural framing for support
2. Use roof or floor for the slope roof/shade
Corsten
Building Designer
Message 9 of 10
hemmanu
thanks much.
Message 10 of 10
hemmanu
hi,
in the family templates there is no structural framing alone so i created it with the beam option,
although i have locked all parameters and dimension, when i loaded it to the project the shape was changed according to the length of the beam line and etc.
then i have created it with the "structural framing - Complex and Trusses and i could get a fixed dimensions shape in the project.
did you meant to create it in a different template?
