WALLS - Corner intersection in plan
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
lukearh
441 Aufrufe, 2 Antworten
I have the following situation:
Two walls at a corner of a building (in PLAN), and I want only the exterior component to continue beyond the corner.
I attached 2 pictures to ilustrate the isuue. In the 1st picture is the situation in REVIT, in the second is the result I want (done in ACA).
How can it be done in Revit.
Thank you.
2 ANTWORTEN 2
Nachricht 2 von 3
RDAOU
als Antwort auf: lukearh
@lukearh
Easiest is to use a combination of 2 wall types...
  • First type UP TO the corner (with the 3 layer Gyps/Metal/Sandwich)
  • Second Type FROM the Corner Onward  (with only the Sandwich)
Alternatively you can split that wall into parts and:
  1. Either Divide and Exclude the layers/Parts which you do not want to extend beyond the corner
  2. Enable shape handles and draw/adjust the layers back to the corner
Nachricht 3 von 3
lukearh
These 2 options I had in mind also. Out of the 2, the 1st one is the prefered one.If creating parts, I cannot for ex. add / edit walls or doors.
thank you
