Hello all,
I have created two different walls in the same level. How can I control the thickness of the exterior line of each wall?
Thank you in advance!
Try Changing the Projection and cut line weights in the highlighted section in image.
Creat a filter by wall type.
Help Page Revit 2018 - Creat a filter
It seems that the filters is the answer.
When I change the Projection and cut line weight in Object Style nothing happens..
@mairh_tsek wrote:It seems that the filters is the answer.
If nothing happens when you change the Object Style Projection or Cut Line Style, then you must have Graphic Overrides controlling them in the View. But, I agree: we define filters and assign them to the views for this kind of thing.
Object Styles control the graphics of categories, not individual types or instances. Using Filters is definitely the answer.
You probably have Cut Line Styles checked on the [ Override Host Layers ] panel in the Visibility Graphics Dialog.
The Line Thickness is then defined for each layer function.
