walls connection to each other
6 ANTWORTEN 6
Nachricht 1 von 7
393 Aufrufe, 6 Antworten
I am drawing the insulation as a separate wall. when I define the function of in the edit family, as insulation, the bearing walls shoots through the insulation I modelled at the end. can I avoid this without having to change the function of both walls to an equal function?
Thanks!
6 ANTWORTEN 6
Nachricht 2 von 7
ennujozlagam
als Antwort auf: Anonymous
You can try this and see if helps. Thanks
Nachricht 3 von 7
als Antwort auf: ennujozlagam
@ennujozlagam I cant see .. in your reply..
Nachricht 4 von 7
ennujozlagam
Nachricht 5 von 7
@ennujozlagam nope, I couldnt find a solution ??
here is the same problem again, I want to join the 2 red cross-hatched walls, which ar non-bearing, but the green bearing wall keeps pushing itself into the joint..
Nachricht 6 von 7
ennujozlagam
Your wall must be one type with other layer.
Nachricht 7 von 7
Disable Auto Join (e.g. Disallow Join).
You can always use Join Geometry to hide the Visible Edges between the Walls that touch each other.
