My walls are appearing differently in certain groups across my model and I can't figure out why. As per the screenshot, the two apartments shown are mirrored and are the same view. The apartment on the left correctly shows the walls in at a "FINE" detail level and at the correct color as per the filters.
The apartment group on the right, despite being the same mirrored group, appears to be stuck at a coarse detail level and with thin grey outlines. However, it adopts the correct color fill from the filter.
Please could anyone help me understand what I'm missing?
Thanks!
Gelöst! Gehe zur Lösung
Gelöst von sam96131. Gehe zur Lösung
If you can share a small portion of your project Revit Model that might help figuring out the issue.
I checked the phasing but it wasn't that. For some reason the plan regions seemed to have bugged out. I deleted it and copied one from a higher level (where the floor was displaying correctly), pasted it in with the exact same levels / offsets as the deleted plan region, and now the walls inside are correctly displaying as per the applied filters.
I should have noticed that sooner, since it was only walls within certain plan regions throughout the model.
