Walls and roof showing walls behind as if a transparency is set
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
chrisYHPRZ
958 Aufrufe, 6 Antworten
My wall and roof are showing walls which are behind, how can I stop this. No transparency is set and no view templates are set. I am working in Revit LT 2020.2
Beschriftungen (2)
6 ANTWORTEN 6
Nachricht 2 von 7
idrisbahadur
als Antwort auf: chrisYHPRZ
It may be a graphic card issue. You can try this:
File > Options > Graphics > Graphics Mode > Turn off Use Hardware Acceleration
İdris Bahadur
Nachricht 3 von 7
chrisYHPRZ
als Antwort auf: idrisbahadur
Thanks for the suggestion but its not that. I realised I was still in 2020 and have recently download 2021 but the issue remains in 2021.
Nachricht 4 von 7
syman2000
Check you eye elevation and target elevation. Make sure the value isn't a huge number. To reset it, use the view cube and click on the isometric.
Nachricht 5 von 7
chrisYHPRZ
als Antwort auf: syman2000
Hi, thanks I tried your solution but it didn't work. I've realised it's not just in 3d if I go to elevations then I have the same issue.
Nachricht 6 von 7
syman2000
Do you have CAD link to your Revit file? Try removing it
Nachricht 7 von 7
chrisYHPRZ
thanks for your time and solution
