Hi, I have a Walls and Ceiling Problem
I don’t understand why when I go to the ceiling view, I can only see some of the families and elements inside the view. But I cannot see any wall.
It’s like the ceilings aren't working properly. Help please!
Gelöst! Gehe zur Lösung
Gelöst von aRcHiTeCt.JM. Gehe zur Lösung
… hi @Anonymous
… check your view template
… also check in your visibility graphics
… if walls are unchecked ?
… check the cut plane of the ceiling
… check the view range settings of the ceiling view
… check the detail level
… check if you are hiding/isolating elements
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
… cont … @Anonymous
… check if you didn’t draw the ceiling on top or above the next floor
…. cut a section and see where is the elevation of the ceiling
… if so move it down
… check the depth clipping
… check the phasing
… sometimes the drawing is in the wrong phase
… if nothing from above
… zip and upload your project to take a look
aRcHiTeCt.JM
REVIT EXPERT ELITE
