Walls always move Other Walls?
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
BigPicture045
292 Aufrufe, 3 Antworten
Is there a shortcut or option that will allow walls that interfere with other walls to not auto-move them? I am using walls to create a chimney and need to move the top walls but each time I move them it moves the bottom walls as well.
I have to separate the geometry completely the then put it back. I am posting because this seems like a tideous process and wondering if there is an option I haven't come across....
Edit: Even when Geometry is not touching the upper and lower walls still move together:
This feature is also good in general because often walls get moved around without meaning. This happens often when modeling.
I know I can check the "Disallow Join" but I need this if I am making a chain of walls I want joined.
3 ANTWORTEN 3
Nachricht 2 von 4
syman2000
als Antwort auf: BigPicture045
Why not create a stack wall for this condition? when you move the wall, the top portion will move with it.
Nachricht 3 von 4
GaryOrrMBI
There isn't a "Disallow Join" for top and bottom automatic joins anyway.
The manual method would be to put a Check in the Disjoin option in the options bar of the move command:
Gary J. Orr
GaryOrrMBI (MBI Companies 2014-Current)
aka (past user names):
Gary_J_Orr (GOMO Stuff 2008-2014);
OrrG (Forum Studio 2005-2008);
Gary J. Orr (LHB Inc 2002-2005);
Orr, Gary J. (Gossen Livingston 1997-2002)
Nachricht 4 von 4
BigPicture045
This is a good solution. Thanks.
