wall wraps
14 ANTWORTEN 14
GELÖST
Nachricht 1 von 15
BIM_Dreamer
991 Aufrufe, 14 Antworten
wall wraps
how to make wall wraps (blue colour) on top portion and continous wall bellow and delete excess wall. see attached. thanks you.
14 ANTWORTEN 14
Nachricht 2 von 15
als Antwort auf: BIM_Dreamer
Maybe you can post a file so that we won't have to recreate that from a scratch.
Nachricht 3 von 15
FGPerraudin
hi BIM dreamer,
For the top wrap, I am afraid that you will have to make a wall sweep.
If it is always there, integrate the sweep as part of your wall structure (Wall type properties>structure>switch to elevation view or the sweep option will not be available!)
If it is not, make individual sweeps (Architecture > Build > Wall > Sweep, you will have to be in an elevation or 3D view for the tool to be active)
About the bottom issue, is is simply due to the priority of layers between your wall and your slab layers.
They interact the same way as walls do!
Just integrate the grey part of you slab in your slab core, and push the interior finishing part of your wall out of the core!
When you add geometry, the jonction will work just fine!
Cheers,
François
Francois-Gabriel Perraudin
BIM management and coaching
Nachricht 4 von 15
BIM_Dreamer
als Antwort auf: ToanDN
hi, attached file.
Nachricht 5 von 15
BIM_Dreamer
als Antwort auf: FGPerraudin
@FGPerraudin not possible to create individual sweep (time consuming)  i have a lot of area with this type of walls. thanks you
Nachricht 6 von 15
FGPerraudin
Then maybe you should creat two types of walls?
One with the sweep, one without, and assign each type according to the situation?
I haven't had a look at your file yet but I will...!
Nachricht 7 von 15
Keith_Wilkinson
Are we looking at a plan or a section?  The column in the corner would seem to indicate the former - I've not had time to look at the file but it will affect the options available.
"Give a man a fish and you feed him for a day; teach a man to fish and you feed him for a lifetime."
Maimonides
Nachricht 8 von 15
BIM_Dreamer
als Antwort auf: Keith_Wilkinson
you're looking at a plan. just ignore the column (colour green) nothing to do with the problem.
Nachricht 9 von 15
Keith_Wilkinson
Trouble is your snippet looks like a section which is how @FGPerraudin has answered your question but the solutions provided won't work in plan.
Maimonides
Nachricht 10 von 15
FGPerraudin
My bad, I thought it was a section cut...
Nachricht 11 von 15
BIM.Consultant
See attached image. For the bottom wall, I extended it to the core then used join geometry.
However, I recommend doing the internal 2 layers as a separate wall since your interior is same type but your exterior varies in thickness.
Nachricht 12 von 15
constantin.stroescu
I thought too that it was a vertical section...
If it is a plan View - and I see now, it is , then you can use a third wall as connector.
I use frequently this method in such cases and it works...
Constantin Stroescu
Nachricht 13 von 15
BIM_Dreamer
als Antwort auf: BIM.Consultant
hi, thank you can you please attached the files of your screen shot. thank you
Nachricht 14 von 15
constantin.stroescu
hello,
You have the file in attachment.
I use sometimes (as in this case) a simplified wall as the third wall -connector in order to make it easier for Revit to make calculations.
Constantin Stroescu
Nachricht 15 von 15
BIM_Dreamer
als Antwort auf: constantin.stroescu
@constantin.stroescu hi, thank you i attached the file (in my previous posted replies) because i want to know if this actual type of wall can be done and can solve the issue but because you used simplified wall my doubt is there. attached my screen shot after modified. thank you.
