Wall wrappings - windows vs doors?
clausneergaard
clausneergaard
Hello all -
I am wondering if there's a difference between doing wrappings of walls around windows vs doors?
Attached image is of two walls of the same type, and then a door insertion as well as a window insertion ... where can I go to adjust these possible wrappings around the door?
I've watched the following video - https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/screencast/Main/Details/cde... - and that's what brought me the correct wrapping of the window-family insert. I cannot, though, get the same effect around my door?
Thanks in advance.
/Claus
clausneergaard
... and I've figured it out. The window family as well as the door family has a native parameter under "Construction" that is called Wall Closure; and this is what I've changed to "By host".
Thanks.
