wall won't split
5 ANTWORTEN 5
Nachricht 1 von 6
1878 Aufrufe, 5 Antworten
wall won't split
I've a few walls that just wont split, either without or without gap. The workset is editable, a duplicated wall will split, i've no idea what i'm missing, any help is appreciated
Tags (1)
5 ANTWORTEN 5
Nachricht 2 von 6
Lakshman01
als Antwort auf: Anonymous
@Anonymous  The wall is stacked wall or Basic wall?  Attach the snapshot for more clearance....thanks
Nachricht 3 von 6
loboarch
Pinned?  In a design option?  In a different phase? Not a wall, but an in place family? Part of a link? In group?  If you can post a part of the file where this is happening, maybe someone can trouble shoot more.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Nachricht 4 von 6
als Antwort auf: loboarch
Its not pinned, not phased, not an in place family, link or group or array, when i copy the wall the duplicated one splits no problem. How would i know if its in a design option?
Many thanks for your help, it has me completely stumped.
Nachricht 5 von 6
GREMMELS1
I just ran into this same issue.  When I selected the wall it said it wasn't pinned.  I then tried pinning it and then unpinning it.  Still wouldn't split.  Instead of copying the wall I then tried to move the wall.  Revit flagged it and said can't move pinned element even though I had just pinned and unpinned.  Then after trying to move the wall I selected it again and this time it said the element was pinned.  I unpinned it and it was able to split as usual.
Nachricht 6 von 6
pallston
Possibly check to see if there had been a painted surface, or split face already done to the wall.
If you're trying to split a wall along/close by a split 'face' Revit may be having issues reconciling.
