wall with slope niche
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
880 Aufrufe, 9 Antworten
hi
Please, how can I modeling a slope niche in a wall ?
9 ANTWORTEN 9
Nachricht 2 von 10
BIMAbhi
als Antwort auf: Anonymous
You can use Massing tool to create slope wall.
Thanks & Regards
BIMAbhi
Nachricht 3 von 10
loboarch
I would use an in-place model void set to cut the wall geometry to do something like that.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Nachricht 4 von 10
constantin.stroescu
I'll use a Wall based or Face Based Family created with a Void with parameters and then loaded into Project . The advantage of this method is that you can use as multiple instances in the project.
Constantin Stroescu
Nachricht 5 von 10
als Antwort auf: constantin.stroescu
I testing this solution with a parametric family :niche_penché_famille.PNG
But the void is not created in the wall :
[edit] I joint the Family.rfa file
Nachricht 6 von 10
constantin.stroescu
you have already solved the problem , but anyway I post also my screencast , maybe it will help somebody..
https://knowledge.autodesk.com/community/screencast/5105a1b5-7bcf-42bb-ac6c-577795626b0b
Constantin Stroescu
Nachricht 7 von 10
"you have already solved the problem ... "
No ... sorry but no, my problem is not solved ... the wall don't accept the void of my family Smiley (traurig)
Nachricht 8 von 10
It works here.  By the way, the family does not flex properly to different wall thickness. You may need to look at that.
Nachricht 9 von 10
constantin.stroescu
try it now - I've load a Depth Parameter instead of a Locked dimension...
Constantin Stroescu
Nachricht 10 von 10
It is not the problem ... I find it : The wall and the family instance was not on the same phase :
Thank you very much ! Smiley (überglücklich)
