Dear to all,
There are so many different widths of walls (as per in the drawing I have attached)
so Please tell me how to draw different width of walls in one drawing
Gelöst! Gehe zur Lösung
Gelöst von mumarshad. Gehe zur Lösung
Gelöst von chrisplyler. Gehe zur Lösung
Gelöst von ennujozlagam. Gehe zur Lösung
I tried to change different width then all the wall changes to new width
so please help me how to do it
Please!!!!
Each wall TYPE can have its own structure of layers defined that add up to a desired width.
When you selected a wall and changed it's width, you changed every wall of that type. What you need is multiple types.
Pick an existing wall type, EDIT the type, DUPLICATE the type, give that new duplicated type a unique name, EDIT the STRUCTURE of that new type to include the layers that result in the desired total width.
