Wall tag not properly placing
5 ANTWORTEN 5
Nachricht 1 von 6
PrathapSekar
438 Aufrufe, 5 Antworten
Hi Masters!!!
Please have a look over the image attached below. While placing wall tag in exact horizontal and vertical walls (walls has similar properties) its placing properly, but its not working on angled walls texts are going out of the border. Please help me to get rid of this. Thanks in advance.Wall Tag_Rotate.PNG
Thank You! and please 'Accept As Solution' when you found a solution, to help others.
5 ANTWORTEN 5
Nachricht 2 von 6
Sahay_R
als Antwort auf: PrathapSekar
Smaller text is one thing that does come to mind.
Can you also share the family please?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 3 von 6
PrathapSekar
als Antwort auf: Sahay_R
Thanks @Sahay_R
Attached the family.
Nachricht 4 von 6
Sahay_R
Hi @PrathapSekar
I did play with the family and compared it to the tags that we use. The behavior of both was similar.
In the interests of legibility, our tag does not rotate with component.
I did try smaller font - 1.5 instead of 2mm, and the labels did stay within the tag. That may be the solution.
Rina Sahay
Nachricht 5 von 6
PrathapSekar
Thanks @Sahay_R
But for our standard we required to keep the text size as 2 or 2.5 mm height.
Nachricht 6 von 6
Sahay_R
Is the size for the box also at standard? Because the next thought that comes to mind is a larger box.
Rina Sahay
