i want to remove leader arrow point from center of the circle as shown .not getting any clue
Are you talking about the "Dot-Open" Leader Arrowhead and how the leader originates the center of the circle? That's just the way it is. You can't position the leader origin differently.
FWIW: You need a custom Arrowhead. Unfortunately, Revit doesn't allow customized Arrowheads. ![]()
Not Ideal, but your update your circle arrowhead to have a solid white filled region.
when you go to edit the circle arrowhead, you'll see that it is located centered to the two reference lines. the intersection of the two reference lines is the end of your leader line. this may not be your office standard, but I suggest you make the circle a black fill. it would resolve this issue altogether, also it looks more obvious!
