I've hidden the wall sweeps in the visibility graphics selection box but they dont seem to get hidden. What could be the problem?
Solved by barthbradley. Go to Solution.
You are talking Wall SWEEPS - not REVEALS; right?
See if you can turn them off via Override Graphics in View (in right-click drop-down). Also, I'm wondering if they might be additionally controlled by a Filter.
Yes, I am talking about wall sweep not reveals.
I already clicked on Visibility / Graphic override and unchecked to the walls sweeps under walls. However, I still see the wall sweeps.
In the view in which the Subcategory "Wall Sweeps - Cornices" is unchecked, and the Wall Sweeps are still visible...
Select one Wall Sweep, right-click mouse and select "Overrride Graphics in View"=>"By Category".
What happens? Do all the Wall Sweeps disappear from the View? If they do, then they are not Wall Sweeps (e.g. created using the Wall Sweeps tool). If they don't all disappear, then...
...thinking...
Loading. One moment please.
When I select a wallsweep and right-click to "Override Graphics in View" the "By Category" is greyed out so I cant select it. What I can select is "By Element" and hide it that way. But it means I have to select each wallsweep individually.
Could there be some sort of glitch in Revit 19 for this function to not function at all? Or, could it be because the file was upgraded from Revit 18?
Under Type Properties for the Wall Sweep, what does the "Subcategory of Walls" parameter read?
Are the sweeps built into the Wall Type? If so, they cannot be turned off via VG.
The wall sweeps are not built into the wall type. Interestingly when I opened the Type Properties, the "Subcategory of Walls" is <none>. I changed it to Wall sweeps and it seemed to work.
<none>??? Well, there you have it. Should be "Wall Sweeps". Working now, right?
all my wall sweeps are set to 'Wall Sweeps - Cornice'. my problem (floor plan) that my horizontal sweeps get turned off when the category is turned off but my vertical sweeps are still showing up. also noticed that my horizontal weeps are level based while my verticals do not.
