I'm trying to utilize some wall sweeps in a project I'm working on, in particular, in a siding product I'm hoping to implement into the design. The issue here is that he siding works perfectly fine as long as we are dealing with orthogonal interactions. It absolutely doesn't work with others, to my knowledge. For example, when the horizontal siding interacts with the slanted roof it wants to chop the siding back wherever the original point of the profile intersects the lines of the cutting plane. Obviously I'd prefer that the siding matches the slope of the roof, which is how it would actually be constructed. So far the only solution I can come up with is to in effect create a model in place infill component to solve the problem but other than that I'm stuck.
Does anyone else have a solution beside the model-in-place one I'm currently on?
