WALL SWEEP
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
maurizio.schiavo
1265 Aufrufe, 1 Antwort
WALL SWEEP
Hi to all.
Anyone of You knows how to built a parametric sweep profile to a wall sweep feature? I note, but I don't want to have done some errors ... that it's impossible to make a parametric sweep profile on wall. This function shall be usefull in order to make a structural shelf with the possibility to change it quicky by parametric during the modeling phase instead of make it as rigid profile.
1 ANTWORT 1
Nachricht 2 von 2
Remember that the Wall Sweeps responds to a PROFILE, so, if you edit the family of the profile, and ad a dimension with a parameter, then in your proyect you can edit that parameter, but NOT in te Wall Sweep properties, you have to do it in the PROFILE properties, entering trought the proyect browser.
Please, if the answer helped you, mark it as a solution :lächelndes_Gesicht_mit_lächelnden_Augen:
