We apply wall sweeps to create skirting and wall trims on our detail drawings for the interior design. Funny thing is the material takeoff schedule will show the material used for the skirt but not for the wall trim.
Any thoughts on what we can do for them to show up? Bare in mind that the wall sweeps are not embedded in the wall and we have Marks applied in the wall sweeps.
Thanks in advance.
Gelöst! Gehe zur Lösung
Gelöst von Avaris.. Gehe zur Lösung
This is unfortunately a Revit 'problem', it has been asked before, you are not the first one.
The solution provided in that link, suggests to make a line-based family.
Another thing you can try is to make the wall sweep in parts. Never tested it, but maybe it works.
I saw on the forum about it...but my curiosity is why one will show and another one don't?
our skirting is a wall sweep the process of applying material to it an Marks has been the same for the trims but these ones don't show. Is quite odd that one will and another one don't.
Could be something because of the standard family wall seep? is the only thing I can think about it.
Cheers
If you made them exactly the same way, you can try if it depends on interior/exterior. So try to place a trim at the outside. But that is not a solution only to discover what could be the difference.
And making it parts, does that work (second link in my previous post)?
Thanks a lot as soon as I convert to parts will show in the schedule...
Cheers
Claudia
