Wall Sweep end points
4 ANTWORTEN 4
Nachricht 1 von 5
399 Aufrufe, 4 Antworten
How to get the Wall Sweep end points? I got null on WallSweep.Location as LocationCurve (single Wall Sweep).
Also, each side of a Wall Sweep, if it is a polygon.
[In image: One wall sweep outside bedroom at Wall-015 and polygon wall sweep inside bedroom at Wall-009, Wall-010, Wall-011, Wall-012, Wall-013, Wall-014, and Wall-015.]
Beschriftungen (1)
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
Say what?  Did you take a wrong turn on the way to the API forum?
Nachricht 3 von 5
syman2000
Wall Sweep can be hit and miss. Have you try using alternative like railing? I find that to be more reliable and flexible.
Nachricht 4 von 5
Have you tried editing wall sweep in a 3D view?  If not -- try it; you 'll like it.
Nachricht 5 von 5
als Antwort auf: barthbradley
