Wall Sweep and openings from windows
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
2597 Aufrufe, 5 Antworten
Hi
I have trouble getting Wall Sweeps to cut through both wall and sweep at
the same time.
I have tried several different solutions, and the closest thing I have come to
with is that I can cut the whole sweep away where the window is.
Has tried to change the window's family's void.
Hope someone has a solution :leicht_lächelndes_Gesicht:
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Anonymous
I don't see any Wall Sweep in your images.  What did you model the curved part with?
Nachricht 3 von 6
als Antwort auf: ToanDN
Hi
The highlighted element on the image is the wall sweepet.
The overall goal of this project is to make a wall curved on the front and flat on the back.
Therefore i have the choice to try to solve this with a wall sweep.
Nachricht 4 von 6
FGPerraudin
hi @Anonymous,
In your case, model you wall in place.
a sweep is made for modeling ponctual elements, not whole walls.
You could have a modeled in place and a classic wall that you then join.
doesn't work just tried.
Just model your wall in place!
François-Gabriel
Francois-Gabriel Perraudin
BIM management and coaching
Nachricht 5 von 6
als Antwort auf: FGPerraudin
@Anonymous  either build the entire wall as an in-place model as @FGPerraudin has suggested, or build a thick wall and cut it with a curved void.
Nachricht 6 von 6
