wall surface color at cut feaces
tareqathamneh6QW84
tareqathamneh6QW84
the wall surface at the lower side of the window is gray, but I want it simply white. in this particular wall any window will do that. I checked all materials within the wall and found no gray. What is the source of this gray?
Thanks!
Use the Paint Tool to paint it white.
...betcha the Wall Wraps at Inserts. Am I right?
....FWIW:  Grey typically (not always) denotes "BY CATEGORY" Material (e.g. the Material assigned to the Category under Object Styles).
The gray color is from the material assign to Walls category under Object Styles.  It is usually Default Wall material.
