Wall/Slab join with wrong representation
1 ANTWORT 1
Nachricht 1 von 2
brunoc_schreiber
254 Aufrufe, 1 Antwort
Hello guys,
I'm making a view standard wich the structural part of the walls and the structural part of the slab should be shown in a thick line and the finishers in a thin line. But I'm having some trouble with the way Revit tries to show it.
Does anyone knows a way to fix it?
All the finishers are using the same materials, the only differece is in the wall core material (masonry) and the slab core material (concrete).
(the VG in the screen shot is in portuguese but I think it's easy to understand what I'm trying)
Bruno Schreiber
1 ANTWORT 1
Nachricht 2 von 2
Orsolya.Balazs
als Antwort auf: brunoc_schreiber
Hi Bruno,
An idea would be to use linework for the line override of the layers or you could use filter override. Filter override is a bit tricky, but you could achive the display thorugh the following steps:
1. Create parts from the floor
2. Add a comment to the specific part of the wall layers
3. In VG dialog/ Filter override create a filter for parts and create a filter rule after the specific comment:
Orsolya Balazs
Product Support Analyst - AEC
Autodesk, Inc.
