Wall showing black in view
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
ubaldurban
6417 Aufrufe, 2 Antworten
One of the wall types shows black - material assigned is metal but both section and view is set to grey in material settings.
Template controlling the view has an override for walls in grey. The only way to change the color is by applying filters or overriding it in view.
It looks like it is something to do with the template but cannot figure out what exactly.
Many thanks for your time.
2 ANTWORTEN 2
Nachricht 2 von 3
martijn_pater
als Antwort auf: ubaldurban
Check detail level for the view (template), it's probably set to course with course material.
Because the detail level is set to course, the wall type shows according to settings which you'll find when editing the wall type under graphics course scale pattern and fill color.
Nachricht 3 von 3
ubaldurban
als Antwort auf: martijn_pater
Thank you for the response.
It was not the issue this time. We have figured out there was a Filter applied to the template with a parameter that the wall was assigned to.
Now everything works fine.
