Wall shaded appearance
10 ANTWORTEN 10
GELÖST
Nachricht 1 von 11
tmccar
1115 Aufrufe, 10 Antworten
The sloping wall was modelled in place, and has the same material as the straight wall. Why is the appearance different?
10 ANTWORTEN 10
Nachricht 2 von 11
cbcarch
als Antwort auf: tmccar
Different Phase?
Check wall Phase, and/or Set View Phase Filter to Show Complete
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 3 von 11
Is the model in place category correct? Is that category being overridden in the view template or visibility graphics?
Nachricht 4 von 11
tmccar
als Antwort auf: cbcarch
@cbcarchwrote:
Different Phase?
They're both "New Construction"
Nachricht 5 von 11
tmccar
als Antwort auf: Anonymous
It was definitely modelled using the Wall category.
There's no view template
Nachricht 6 von 11
cbcarch
Any "Paint" applied? Try "Remove Paint" or set to "By Category"
Triple check if Material is identical to other system wall families.
Cliff B. Collins
Nachricht 7 von 11
Did you assign the material to the solid in the editing mode?
I don't see the entire wall but from what I see, it can be done with normal wall with edited profile.
Nachricht 8 von 11
tmccar
No paint applied and material is "cast in place concrete" like other wall.
Nachricht 9 von 11
tmccar
als Antwort auf: ToanDN
How can this be achieved with a normal wall?
Nachricht 10 von 11
Edit profile.
Nachricht 11 von 11
tmccar
@ToanDNwrote:
Edit profile.
Thank You
