I am creating a wall schedule and would like to have a column displaying the wall coarse scale fill colour. That is for cross referencing purposes as I have a set a plans that shows the walls in colour.
Is there a way to add the wall fill colour to the schedule.
Thank you,
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
You cannot. If you must, use Type Image field referencing images with colors matching Wall types' coarse scale colors.
Hmm, good option but a better solution would be for Autodesk to open the possibility of a field that displays the colour as it is then less clicks for a user to include this useful information in a schedule.
I am currently looking at this and it is prohibitively time consuming to create the jpegs which may or may not match the course scale colour when printed!
