Hi!
I'm looking for a way to build a Wall Schedule which would also show the doors/windows present on each wall.
I tried using the Mark parameter, inputting for each wall the tag number of each door and window, but it's too much work for a big project. Is there a way to automatically show which doors or windows are on each wall?
Example: I want a schedule like this:
Wall Schedule
Type | Area | Height | Window | Door |
Concrete | 4 m² | 2 m | W01 | D01 |
Brick | 6 m² | 2 m | W02 | D02 |
If anyone could help me please! Thanks ![]()
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Hmm then it won't work for what I need. I need the type and area of the wall and then the window/door on that wall. Bc the way I have to pay my wall contractor is by discounting only windows or door areas bigger than 2 sq.m. Less than that, I pay as if it was a whole wall, with no openings.
Thanks!
If you create a Wall schedule with an Area parameter field, it will calculate the area of the wall minus the area of doors and windows. This might help.....
Edit: I made a mistake. The contract wall area should be the Wall Area + the Area of Doors/Windows less than 2 sqm like in the image below. the screencast show subtraction and it is wrong. Revit 2017 file attached.
@Anonymous
Dynamo can help speed it up by reading the Wall ID and writing it to the Doors/Windows ID for scheduling, and potentially reading the Doors/Windows Area (with < 2 m2 filter) and writing it back to the Walls.
See screencast for a manual approach. It's kinda long because I did it from scratch and on the fly with my thought process.
Here is another approach. Put all the windows less than 2m2 in a later phase. Schedule your walls in the current phase and it should exclude those windows area.
Thank you for the screencast and all your support!!
If I was modeling from zero I believe that would be the best solution, even though it's still very "manual" (would have to input each window and door area into the wall schedule - even though I could export everything to Excel and do it quick).
But since I got a finished model from the architects the last option you suggested fits my needs in a better way.
You can add a formula driven Area parameter to the window families, and have them involved in the schedule and the calculation formula. Less manual involvement for you.
