Wall Schedule Error
Wall Schedule Error
David_MM
Wall Schedule Error
David_MM
Has anyone encountered this issue with wall type schedules before, and if so, any idea on a fix?  We are running Revit 2018.3.
Please see the attached screenshot.
All of my active projects now show like this.  When my coworkers open the same file, they display normal.
David
cbcarch
-Sounds like you might need to create a new local file, then STC, as everyone else is reporting correctly.
-I noticed you have a few Add-ins,--do the rest of the team all have exactly the same add-ins on their pc's?
-Is everyone on exactly the same build of Revit?
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
David_MM
It is displaying incorrectly in central files, local files and files with no worksets.
We all have the same setup as far as addons go.  Some are still in 2018.2 others are in 2018.3.
Could it possibly be a graphics card issue?
David
cbcarch
Get everyone on the same build--this is critical. File corruption may result.
Try creating a new Project, place a few walls and create a Wall Schedule. Does it work?
Cliff B. Collins
David_MM
Good idea Cliff!
I created a new project, added walls and created a new wall schedule and the information showed up on the schedule correctly.
I then copied in our standard wall type schedule to this new project and nothing displayed in that schedule.
So for now, it seems the solution would be for me to use a different schedule than the rest of the company.
It would be nice to understand why this is happening though.
David
cbcarch
Odd that it works in a new project, but not on yours.
Another thought:
-Does the Wall Schedule have a View Template applied to it? If so, un-apply/set to None.
-Check Filters in the Wall Schedule
Cliff B. Collins
David_MM
Thanks for the suggestion of trying a new project and creating a new schedule, that seemed to work.
I created a new schedule in my project and now its displaying correctly.  At least this is a viable workaround.
There are no view templates applied and i removed all filters on the trouble schedules with no fix.
Thanks again,
David
