Hello!
I have made a roof using Dynamo, and I am having difficulty attaching my walls to the roof.
Here are some screenshots:
I have read some other forum posts with similar problems, however none of those solutions seemed to work for me.
Any help is greatly appreciated!
Gelöst! Gehe zur Lösung
Gelöst von BDMackey. Gehe zur Lösung
EDIT:
Walls refuse to even attach to a basic floor. ![]()
Here is the revit file:
I think some of the curves are too tight for Revit to understand. If you change the thickness of the roof to 1/8" (3mm) thick then the walls attach. I didn't keep stepping up the thickness to see when it breaks but they will attach.
FYI It also fails on creating the roof if you use the surface as the bottom of the roof instead of the top.
Thanks! I went ahead and tried that - and it worked for the glass and mullion walls - but not for the 6" thick walls. Hmm. Messing with the thickness seems to do lots of things ![]()
I thought that too, and fixed it, but still the same problem. For some reason the walls refuse to even attach to a flat floor.
