Wall Reveal wont cut mitered corner
2 ANTWORTEN 2
Nachricht 1 von 3
chelseakotun
456 Aufrufe, 2 Antworten
I am trying to use the Wall Reveal tool to create a bullnosed wall opening. When I drag the ends of a vertical and horizontal sweep together, it creates a mitered corner but does not cut the wall with the corner. I am able to tell that the miter is created because when I click on the reveals the outline of the miter is present. Does anyone know what I'm doing wrong?
Tags (2)
Beschriftungen (1)
  • Help
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: chelseakotun
Why not model the Reveal In-Place along a continuous 3D Path?
...if you don't have In-Place Modeling capabilities, then model it in a Window Family Template.
Nachricht 3 von 3
RDAOU
@chelseakotun
Using the standard Reveal/Sweep tool does not always give the desired results and/or it can be quite a tedious process to generate the desired results.
Try the attached family from a previous post on the same subject .
