I am fairly new to Revit and have some basics down. But I am having an issue with changing the reveal without it changing it on other walls. What I tried was creating a new reveal profile for the new size I want and this changes the other reveal profiles. I also tried creating a new wall by duplication and changing the name, but it still doesn't help.
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Reveals are made using a Profile Types. Duplicate , name and modify the existing REVEAL to make a new Type.
Your are showing the exact same REVEAL TYPE called Reveal. One picture shows the Type using the Reveal1 Profile and the other picture shows the same Type using the Reveal2 Profile. There's only going to be ONE Type named Reveal and it'll will use whatever Profile you last assigned.
Duplicate Reveal TYPE and call it Reveal Two, and then change its Profile to "reveal 2". Then duplicate Reveal Two Type and name the duplicate Reveal One, and then change its Profile to "reveal 1". Now you have 2 Types using 2 different Profiles.
Those pictures I posted are two different profiles with two different sizes. The first one is a 3"x 4" and the second is an 3" x 11". Look at them a little closer. I used duplicate and made the sizes different.
