WALL REVEAL & VOID SHOW FACES IN CAVITY - HOW DO I HIDE THE BOUNDARIES OF THEM??
2 ANTWORTEN 2
Nachricht 1 von 3
JacobDSimpson
947 Aufrufe, 2 Antworten
Hi All,
As the title says and hopefully my image better represents, I am trying to make a void through the first layer of blockwork to the cavity behind.
Unfortunately whenever I do this the wall reveal or void shows a face that is visible in all 3D views and plans, which is obviously undesirable.
Is there any other way I can create a clean cut in the wall which will not show a face between the inner face of the block and the cavity?
Any help would be appreciated and will definitely mark down as a solution to whoever can help me out!
Cheers,
Jacob
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: JacobDSimpson
Do you mean the boundary of the 'Air space' layer?  Do you want them to show like below?
Nachricht 3 von 3
als Antwort auf: ToanDN
Hi ToanDN,
can you let us know how the wall in the image is formed? Is it two walls of blockwork or is there a property to the air cavity?  I am trying to create a 3D view which shows the ‘inside face’ of the wall leafs... rather than a transparent face of the air cavity.
any help much appreciated.
thanks
