Wall "Drafting Surface Pattern" not showing in 2D Elevation
9 ANTWORTEN 9
Nachricht 1 von 10
2439 Aufrufe, 9 Antworten
Hello friends,
I have a wall who's surface pattern is not appearing in 2D Elevation: 1.PNG
You'll notice the pattern is a drafting pattern which means it should show up only in 2D views. The ironic part, it appears in 3D!
Does anyone have any idea what this could be? Perhaps a glitch? Or am I missing something...
FYI:
I am using Revit 2018.
No Visual Graphic Overrides for walls have been applied in the View Template, other than a Projection Line override. No Depth Cueing has been applied.
Thank you!
9 ANTWORTEN 9
Nachricht 2 von 10
als Antwort auf: Anonymous
Looks like you are cutting through it  --- not in front of it.  Move your cut plane away from the wall.
Nachricht 3 von 10
As for the pattern showing in 3D...perhaps someone painted the wall with a material with a model pattern?
Nachricht 4 von 10
als Antwort auf: barthbradley
Hmmm just checked the elevation marker and confirmed the cut plane is not cutting through anything :enttäuschtes_Gesicht:
Nachricht 5 von 10
Tried removing the paint, if there was one on there, none could be found.
UPDATE: Tried creating a new elevation view and the surface pattern appears... Hoping to fix the current view only cause adjusting the datums will be a complete mess.
Perhaps this is a glitch...?
Nachricht 6 von 10
How did create a new one? New or duplicate View?
Nachricht 7 von 10
I created a new elevation. This allowed for the surface pattern to appear.
Duplicating the view didn't solve the issue.
Nachricht 8 von 10
I've had  views become corrupt before, but never over something like this.  Out of curiosity, does Reveal Hidden Elements show anything?
Nachricht 9 von 10
When I click on Reveal Hidden Elements, nothing shows as hidden. Shame Smiley (überglücklich)
Nachricht 10 von 10
mpwuzhere,
