I'm having this really weird glitch in Revit 2023.
I modeled an entire basement space with level 1 being 10' above. I then loaded in a column from Autodesk families in the insert tab. I then needed to model more walls. When I activated the wall tool I noticed that the wall wasnt showing up. Because it took the natural column data. (Base offset defaulted to -10' of Basement level and top constraint to Basement Level) I then go to change the top constraint to Level 1 and I get the error message saying "top constraint is invalid for the level".
Now I cannot draw any walls with top constraint set to anything other than "unconnected". I can edit all of the walls information AFTER its drawn with no issues. But when I click the wall tool and want to edit all its parameters to draw it so I can draw more than 1 consecutively it will not let me. Its such a pain.
Even when I finish making all the edits on the wall to make it correct and then select it and use (CS) "create similar" it activates the wall tool but REVERTS all the parameters I just fixed to the original incorrect parameters that resemble column parameters i.e -10' Base Constraint
Does anyone have a fix for this?
PDF's attached for reference below
Structural Wall default direction is downward - not upward from Level. You can change it on the Options Bar before placing.
Actually, maybe I misread. I see the error message in your Screenshot about invalid Level. Tell me this: what is First Floor Level's Associated Level? Same question for Basement Level. What's its Associated Level?
Basement Level > Basement
First Floor > First Floor
They are associated properly unless i'm missing something
@smaddenXUYER wrote:Thank you but it is an architectural wall, see image of options below
Yes, I see. Looks like Depth is grayed out so you cannot change it. Change the Wall Function.
That worked perfectly. I have never seen that parameter before. Very good to know.
Thank you!
