Wall patterns and other elements disappearing in cut toposolid in Revit 2024
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
lozsi
705 Aufrufe, 8 Antworten
Hello. I have a building pad in Revit 2024 cut out with a void extrusion from a toposolid onto which I am designing a building. Alltough I had performed a cut, some structures are still disappearing as if the toposolid was still there. I am attaching a screenshot to be more illustrative.
Thank You in advance for Your help!
Beschriftungen (5)
8 ANTWORTEN 8
Nachricht 2 von 9
als Antwort auf: lozsi
Post the RVT itself.  Screenshot doesn't help.
Nachricht 3 von 9
lozsi
Hi, thank You for Your speedy reply. Here is a link with the Revit file.
https://drive.google.com/file/d/14t4MOT4J5dqZ-Yt965JrAC6Ch0oXytkp/view?usp=sharing
Nachricht 4 von 9
Can you just directly upload/attach the RVT to a reply post?  I'm unable to scan for viruses.
Nachricht 5 von 9
lozsi
als Antwort auf: barthbradley
Hello. The project has unfortunately 120MB, which is larger than the maximum file size accepted by the site... Can You think of another way to upload?
Thank You in advance.
Nachricht 6 von 9
Compress the file.
Nachricht 7 von 9
lozsi
I have purged unused. Thank You again.
Nachricht 8 von 9
Looks like lowering your View Range Cut Plane slightly resolves the issue.
Before condition:
Nachricht 9 von 9
lozsi
Thank you again!
