wall pattern connects with the column
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
nicol_mukaj
1049 Aufrufe, 3 Antworten
hello, when i connect the wall to the column the wall cut pattern transfers to that of the column please help. This happens on every level.
3 ANTWORTEN 3
Nachricht 2 von 4
indiana_j0nes
als Antwort auf: nicol_mukaj
Thankyou for posting.
This is normal if the materials are the same.
Or is that not the case here? Could you post an image of when they are not connected?
Maybe that can help us narrow down the issue.
Cheers, K
Kunal Tuljaram Gaidhankar
Nachricht 3 von 4
nicol_mukaj
als Antwort auf: indiana_j0nes
hello thank for responding, i just checked if the materials were the same but they are not. if i load another column it has the pattern i firstly selected but if i connect it to the walls  it does the same problem again.
Nachricht 4 von 4
Architectural Column? To prevent this, open Family and Uncheck "Automatically Join Column to Walls."
More here about Join Geometry behavior in general:
Join Geometry | Revit Products 2016 | Autodesk Knowledge Network
