Hi! I wonder where (if possible) you can set the pattern/color for the window cut. I want the part marked in red in the picture to be black. I could paint it, but when you have 100+ windows then it gets very mundane.
Beside painting you have some options.
-You could build something in your window family (similar to the trim here)
-For Walls you can use wrap at inserts (assuming same material as on wall face)
Louis
Please mention Revit version, especially when uploading Revit files.
In that case Better do something inside the family. Add geometry inside the family and add material parameter.
Another option could be to add material parameter to a paint finish perhaps, I'd probably do this with wrapping though...
