Wall paterns.
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
mmyersQ4AUZ
1559 Aufrufe, 4 Antworten
Wall paterns.
What is the best practice to create this pattern in a precast concrete panel.  It will realy be the fluted verticals and horizontal.  Best way to stay? Go!
4 ANTWORTEN 4
Nachricht 2 von 5
mmyersQ4AUZ
als Antwort auf: mmyersQ4AUZ
Nachricht 3 von 5
lucdoucet_msdl
@mmyersQ4AUZ
If your objective is to model the actual fluting rather than simplifying the model, then my choice would be to use a curtain wall with revit curtain panels that are either:
  • a horizontally fluted precast panel;
  • a vertically fluted precast panel or;
  • a window
The windows that bisect a joint between two orientations of fluted patterns could be modelled as a fourth type of panel which would need an distance parameter to align the center mullion with the joint if the modules are not regular.
Hope this helps,
-luc
Nachricht 4 von 5
joe_keogh
If your objective is to simply Apply a Surface pattern (more efficient from a performance point of view), you can use PyRevit's Make Pattern.  Installation instructions here, and there is a good Tutorial here
you can also create a Bump image to apply to the Appearance Assets to give the panel depth in renderings.  I have made plenty of bump images just using gradient hatches in auto cad and exporting an image
Joe Keogh
Director | Design Technology + Innovation
www.viewlistic.com.au
Nachricht 5 von 5
mmyersQ4AUZ
Worked very well.  Thank you gentlemen.
