Wall Parts & Columns showing wrongly in plan
Hi everyone,
I am relatively new to Revit and I am having this problem:
I have created a view filter to hide exterior and interior wall finishes(done through creating wall parts) to show 2 different sets of plan (1 with and the other without finishes). However, doing so makes the columns appear to have a gap between them and the wall. I have tried to look around on how to fix this but no luck yet.
Greatly appreciate the help and time. Thanks!
Accepted solutions (3)
martijn_pater
I guess it could be you're hiding interior finish aswell with the filter, or changed the wall parts' width by accident, or perhaps something with the join order with the columns... Can't really tell, best zip&share the file to have a look...
Why wouldn't they have gaps? Do you want them to be in contact with the wall core? Is so, move them and use Join Geometry - in the correct order - to join the column to the core and remove the portion of finish layer that is between them.
Are they structural or architectural columns? If structural, you need to increase the depth of the columns or move them to the concrete core of the walls. If architectural, then they are in the wrong category, should be under structural columns category.
mauricio_mssf
Hi @Anonymous
It looks like your problems will be solved by switching join order.
1 - Select Swhitch Join Order
2 - Select your structural column
3 - Select your wall
 you can watch this short video to see what i'm saying
https://knowledge.autodesk.com/pt-br/community/screencast/79f03fe6-b121-47fe-9ee3-6e53095d8b48
If the answer solves your problem, click Accept as Solution this helps other users to quickly find an answer and let a like if you liked it.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
