Hi
I created a generic wall 20cm of thickness, I added windows. I created later 25cm thickness wall with plaster and stone cladding as a replacement. For some reason, the wall exist without the opening. It cover the windows from both inside and outside. I don't know what is my mistake.
Many Thanks
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Join geometry doesn't fix? You working with Phasing? Are the windows hosted to another wall?
It looks like. I select the window -> new host. It works. But this way is similar to installing a new window. Is there a better bay to change the host. From instant property for example?
@zs-17 wrote:
Hi
I created a generic wall 20cm of thickness, I added windows. I created later 25cm thickness wall with plaster and stone cladding as a replacement. For some reason, the wall exist without the opening. It cover the windows from both inside and outside. I don't know what is my mistake.Many Thanks
Join the 20 cm wall with the 25 cm wall and the window will penetrate both.
I created a 20 cn generic wall with windows than replaced the 20 cm with 25 cm. In another word I have one wall of 25 cm
