wall material doesnt seen(componen- model in place)
5 ANTWORTEN 5
Nachricht 1 von 6
574 Aufrufe, 5 Antworten
i created a sloped wall with component-model in. i choose the material for this wall but the material doesnt seen in render.
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Anonymous
Did you select the solid in model in-place editing and assign the material?  Is the wall under the current Phase?
Nachricht 3 von 6
als Antwort auf: ToanDN
i had selected just solid extrusion and i drawed the wall after that i select material
Nachricht 4 von 6
when i select the material before drawing, it worked. but i drawed many walls without selecting material, cant i change the material now?
Nachricht 5 von 6
...so your workflow was:
1. Start In-Place Component
2. Categorize as Wall
3. Created an extrusion
4. Assigned a material
5. Close out of In-Place Component
6. Render view with In-Place Component
7. RESULT: In-Place Component Wall doesn't render as expected.
Have you checked to see if the Material's Render Appearance settings are correct?
Do other element's using this material render as expected?
Nachricht 6 von 6
roxanaacaplan
als Antwort auf: barthbradley
Hi, I have a similar problem and my workflow was as you described, what can I do?
