I am attempting to create a door family where the joinery profile changes according to wall thickness and wall material. Basically I have doors in various width metal studs walls and some doors in concrete walls. I managed to get things to work with wall thickness as a conditional parameter, but not when I set the wall material as a condition. Is this possible? Would there be any workarounds? I used the thickness of the concrete walls as a condition for now, but I do have cases in which I have same thickness metal stud walls as concrete walls, and they should look different.
You will just need to take care of the spelling and the upper and lower cases of the material names.
Mostafa Elashmawy
You can use Material parameters as condition yes; however, the how may depend on how many material conditions you have..
