Wall Location Line Shortkey ?
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
2127 Aufrufe, 5 Antworten
Hi everyone !
One of my drawers use to have a short key on a previous software to swap the location line while drawing walls.
Is there a shortkey on Revit 2018 which allow you to swap the location line without  go on the green rubon click on "Location Line" ?
There is no such option in the short key parameters of Revit and nothing is mentionned in Autodesk Help... I checked another forum who says it isn't but since the post was already 8 years old I thought maybe it is now.
Thanks !
Tags (1)
5 ANTWORTEN 5
Nachricht 2 von 6
Ilic.Andrej
als Antwort auf: Anonymous
I'm under the impression he used a plugin shortcut.
Here s a topic about a similar tool.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Nachricht 3 von 6
als Antwort auf: Ilic.Andrej
Only thing that comes to my mind is hitting space key to only switch sides while drawing (but not directly changing location line though)- maybe that was it?
Nachricht 4 von 6
hum... not exactly, I think there isn't such shortcut now :verwirrtes_Gesicht:
maybe in the next version ^^
Nachricht 5 von 6
Alfredo_Medina
Lots of things will be different. Some things from the old software have an equivalent tool. However, most of them don't. And there are a lot of new tools to learn.
Nachricht 6 von 6
Rambazamba73
als Antwort auf: Alfredo_Medina
Why do you mark a topic as solved when it isn`t ? There is no solution yet.
You are ruining the hole forum with this !
