Good day,
I have a problem with the line qualities in the documentation, I have a wall as a layer of paint (thinner thickness) and a wall, but when aligning these walls, the thickest layer of the wall is below the layer of paint, any solution? I can´t change the wall core layer in VG, because I need show other wall core layers
Best regards,
Maybe you can get there by overriding cut line styles in the View.
https://help.autodesk.com/view/RVT/2022/ENU/?guid=GUID-5A8A90EE-F08E-47EC-AA9F-2E281255050D
Make all wall lines very thin via VG or View Template (if only for certain views) or via Object Styles (if for the entire project).
Hi @aurelioKJYJP
Thanks a lot for posting your question to the forums! Has the solution suggested by @ToanDN helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community!
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
