Hey
If i go to object styes and go to wall and change the line weights, nothing happens. Same for visibility/graphic oversides doesnt do anything... I want to change the weight of the walls in my floorpan.
Does anyone know how to fix this
Greets
Aäron
First thing I would check is to make sure you are showing lineweights in the views...I know I have them off most of the time.
If it looks like mine below they are off
It's for printing, if i print now the lines are to thick and it isnt quite nice op paper.. but i don't find how i can do that cause if i change it in object styles under walls and cut. It doesnt do a thing.
If they are too heavy you would need to change them to a different line number either in Object Styles, which is a global change...or in Visibility Graphics which is by view. Below are some screen shots from the out of the box imperial construction template. Line weights are printed thickness.
Object Styles
Line Weights
VG from Plan View
