I have a wall section of walls that is approximately 80' in length. On the floor plan, where I am working, only 70' feet of wall is visible. The other 10' is cut off. The wall is fully visible in other views. What happened and how do I make the wall visible?
Sounds like you need to adjust a crop view region. Click on the icon in a lower left corner of the screen to reveal it and use blue grips to adjust the visible view - see pic.
The Crop View region is the first instinct.
Other possibilities may include (in no particular order of silliness):
1. You've hidden that 10' section.
2. Maybe all 80' isn't vertically the same, and that 10' has fallen outside of the View Range extents.
3. You've got a Masking Region hiding it.
4. The missing 10' has had its color overridden to match your background color.
5. You've zoomed in too much, and that last 10' is off the left side of your screen.
6. You're partially blind in one eye.
7. You've set a View Filter that picks up any wall with a 10' length and turned off its visibility.
8. The view is set to the Structural discipline, but only 70' of the wall is structural.
9. Phases and Phase Filters.
10. Phases and Phase Filters, because it's worth repeating.
