wall layers
10 ANTWORTEN 10
GELÖST
Nachricht 1 von 11
seamea12
772 Aufrufe, 10 Antworten
wall layers
I can not modify layers of compound wall either in model nor in design options .I got such a info-see attached file
Jack
Tags (1)
10 ANTWORTEN 10
Nachricht 2 von 11
als Antwort auf: seamea12
Nachricht 3 von 11
RDAOU
@seamea12
You have the layer already unlocked from the top...Can you specify what exactly are you trying to modify?
Unlock/Split/Merge/Assign Layer...,
Nachricht 4 von 11
seamea12
als Antwort auf: RDAOU
It looks like opened layer but it doesn't work at all .I got info about error (see  attached my file)
Nachricht 5 von 11
seamea12
als Antwort auf: barthbradley
Thanks for a info but I am afraid it is not what I am looking for .I have a compound wall with all locked layers .I'd like to open  layers of my wall . It seems to work and shows unlocked layer  but when I press YES button it shows error info!
Nachricht 6 von 11
Jack
Expand the error message and what it says?
Nachricht 7 von 11
seamea12
als Antwort auf: ToanDN
I attache next file with expanded errors as you asked.
Nachricht 8 von 11
- Write down the two Element IDs and back out of the editor
- Manage > Select by ID > enter one ID then show that particular wall and its properties here (do it for both walls)
Nachricht 9 von 11
seamea12
Nachricht 10 von 11
RDAOU
@seamea12
From the error warning message you posted, the elements in question are in a Design Option set...You need to make that active or make it primary to select those items. You can do that either by managing the design options from the Ribbon>View Tab>Design Options or by using the design option menu on the task bar at the bottom of the view
Nachricht 11 von 11
syman2000
Can you upload the sample file for us to look at?
